TremorJosh
Tremor Newbie
Anyone have a good solution for a 2020 F250 7.3 Gas Tremor wheel spacer. I want 2 - 2 1/2 inch. I ordered a rough country hub centric but I’m the rear hub was still hitting the lip on the spacer and didn’t fit. Help!
Note: This feature currently requires accessing the site using the built-in Safari browser.
I’m with Tremor 6.7 on this. We don’t even run spacers on jeeps anymore, get a better offset wheel.2-2.5” wheel spacers on an 8000 lb truck meant to tow and offroad does not sound safe to me. Why not buy a wider tire and a wheel with a negative offset if you want them to stick out further than stock?
We should really all consider to turn our Tremors into brodozers.I’m with Tremor 6.7 on this. We don’t even run spacers on jeeps anymore, get a better offset wheel.
What is the difference? How are spacers bad
I think the effect is far less pronounced but theoretically still present. That is because the weight distribution lies mostly on the tire/wheel and less on the bearing/hub length.Ok. Then wouldn't offset wheels do the same? You're putting the weight further out either way. What an I missing?
ive lost wheels on both car and truck they are a lot of maintenance have to constantly torque them going from metal to aluminum to aluminum and with heat you have to run them and recheck and re-torque not that they won’t work but there’s a chance you can lose a wheelIt isn't that I couldn't afford the new wheels with a different offset. It's the fact that I bought a tremor so I wouldn't have to buy new wheels and tires. I was hoping to put 1"- 1 1/2" spacers on. Good quality ones in fact. I just want the tires even with the wheel well lip.
