WildHair
Noticed oil on the drive way this evening. Crawled under and found drips on the pan. WTF.... under 2000 babied miles. Any others noticed oil leaks. Does that heat shield (3rd pic) look odd to anyone else
Note: This feature currently requires accessing the site using the built-in Safari browser.
Noooooooo! I hope not!Noticed oil on the drive way this evening. Crawled under and found drips on the pan. WTF.... under 2000 babied miles. Any others noticed oil leaks. Does that heat shield (3rd pic) look odd to anyone else
View attachment 10979View attachment 10980View attachment 10981
Yes drain plug.Is it just the drain bolt?
C
Will wip it off before heading to work and see what it looks like after the drive home. I don't believe the oil level has changed. Check it yesterday when I filled up. I'm not a fan of the twist dip stick. Last three inches it did not want to go in easily.I think it just may appear cross threaded with the oil on it??? Take a pic with the plug wiped off, that will tell you.
Has the oil been changed recently?
Factory oil, was planned on having it done at 2000 miles. Currently 1800 miles on it.I think it just may appear cross threaded with the oil on it??? Take a pic with the plug wiped off, that will tell you.
Did not even notice the plastic shield. Figured those would mass produced with clean cuts.Yea I would say drain plug gasket but crazy looks like they used a jigsaw to cut that plastic shield
