2.5 inch receiver not 3 inch?
stp07030
Tremor Buff
UT
2021 f350 Lariat Tremor
All, 2021 7.3 Tremor finally came in. Went to put on new 3inch BW hitch and receiver opening is 2.5inch? Did I miss something? I thought they came with the 3 inch?
I believe the 6.7 comes with the 3” and the gassers are 2.5.
Thanks...can’t believe I missed that..hope I can exchange the 3inch BW tri ball.
If you have the 7 inch drop 3 inch slide into my private messages. My truck will be here this week and that’s the one I’m going with.
Can anyone confirm that all 2020 plus 7.3 F350 Tremors come with the 2.5 inch receiver? I checked another forum and seems like some do and some don’t. There is mention of towing package for F250’s which comes with the 3inch... Just trying curious if I could have ordered a towing package with my 7.3 F350? I did order the 5th wheel prep...Thanks
Every 7.3 even with the high tow capacity has came with a 2.5 inch ... been talked about alot .... only the 6.7 will get the 3 in.... but you could always get a 3 inch hitch receiver and replace the 2.5 in
I thought it was 250 vs 350 for 2.5 to 3"? Maybe its Ultimate Towing vs not so Ultimate?
My buddy have a 6.7 250 and his has the 3 inch
And my job has a 7.3 XL work truck that's a f350 has a 2.5 inch .. that used for towing so I believe has more engine impact then the badging
Thanks
I can confirm have a 2020 F-350 7.3L Tremor and it only gets the 2.5”. Only ways I know of to get 3” factory is Diesel, DRW, or camper package in the F-350. The HCTTP on the 6.7L F250 also gets the 3” reciver the rest of the F250s get the 2.5” standard and could possibly be optioned to 3” but not aware of option in a Tremor to get the upgrade.
I do wish my F-350 7.3L Tremor had the 3” since it is not the easiest to track down a rental goose neck to take more tongue/pin weight.
Edit,corrected for camper package upgrade.
I can confirm have a 2020 F-350 7.3L and it only gets the 2.5”. Only way to get 3” factory is Diesel or DRW in the F-350. The HCTTP on the 6.7L F250 also gets the 3” reciver the rest of the F250s get the 2.5”.
I do wish my F-350 7.3L had the 3” since it is not the easiest to track down a rental goose neck to take more tongue/pin weight.
Thanks
My 2020 F350 supercab 8' box with factory trailer hitch has 3" receiver.
I suspect it is the camper package that got you the upgrade. Unfortunately the camper package is not available in the Tremor and surprisingly not common in my area on the regular Superduties.
The truck was purchased for hauling a slide in camper when towing a boat. It had the largest payload of all the trucks I looked at - 4200 lbs.
Thanks I will correct my post. The 3” would definitely be nice since the 2.5” has a 1520 lb tongue weight limit.
